Start G-code
mickey
Hi guys first time user here
I have a Anet A6 hobby printer
I have leveled the bed and everything looks great and the XYZ go to home position just fine
I am using the Cura 3.4.1 version on my Mac High Sierra 10.13.6
When save the print file and install the Micro USB into the printer and then I select the print file to print
all the axis move to start printing but the extruder starts going downwards into the bed and gets stuck
I know there is something I can change in the start G code to get it to go to a relative position and just start printing
Can anyone please look at this G-code and tell me what I need to change so I  can print my kids toy replacement part
I have checked the stop switches and they are all in place and operates fine but for some reason the extruder starts going down from left to right
I set went to the venue and set the axis to home position then I went and disabled the motors and manually (slowly) moved the bed to each corner and leveled the bed with the nozzle
Also measured the Z axis to make sure it was not out of alignment and it is perfectly straight on either side.
Your input will be greatly appreciated
G28 ;metric values
G90 ;absolute positioning
M82 ;set extruder to absolute mode
M107 ;start with the fan off
G28 Z10 ;home Z
G1 Z15.0 F840
G1 F200 E3 ;extrude 3mm of feed stock
G1 F840
M117 Printing...
        • 2 replies
