DSM Novamid® ID1030 CF10
SandervG
Posted · DSM Novamid® ID1030 CF10
Through our alliance with larger material manufacturers we're happy to share the first filaments that become available to you through our Ultimaker ecosystem.
One of those new materials is Novamid® ID1030 CF10, it's a carbon fiber filled grade PA6/66 filament. With a 10% carbon fiber reinforcement, it produces stronger, tougher and stiffer 3D printed parts.
On a short notice the materials will be available to you through Ultimaker Cura.
Novamid® ID1030 CF10 Data sheet.
If you have any questions or experiences you want to share about this material, please share them below ?
    Posted (edited) · DSM Novamid® ID1030 CF10
    Thanks for posting - great to finally see Ultimaker endorsing reinforced filaments. What I really like about the technical data sheet is how it explicitely states the properties measured along and across the printing lines (even if the Z-direction is still missing).
    However, the properties stated on the data sheet you linked are different from those I found here on the manufacturer's page: https://www.dsm.com/content/dam/dsm/additive-manufacturing/en_US/documents/novamid-id1030-cf10-leaflet.pdf
    Do you know why they are different, even if they are for the same material?
    Edited by P3D
