16 hours ago, varazir said:So the pre build profiles works with material settings but not customs one. Why is the same data saved in 2 places ?
4
Because there are multiple reasons to change something. Eg; A material needs to change the temperature, but the same can be true for quality or the type of nozzle you are using.
16 hours ago, varazir said:Is there a way I can edit the build in profiles ?
4
Not by means of the GUI.
Smithy 1,146
I am not 100% sure, but a profile saves only the differences to a default profile. So if you have manually set the print temp. before you saved the profile, the temp. is also save and set permanently. If you don't set a temp. and just do some other settings, the temp is not saved and should then work in your custom profile the same way as with the default ones when you change the material.
But thats just theoretical, I haven't tried it, but I know that only changed values were saved.
