Improve the interface of the Support Blocker
celso-santos
Posted · Improve the interface of the Support Blocker
Feature Request - I would like to ask you to improve the interface of the Support Blocker. As soon as we select the part we want to delete, all the drawing becomes gray (Example 2), what is an odd behavior. I suggest that when we select the support part we want to get rid of, it just becomes red (Example 3), so that then we can see clearly what we have selected and then be able to delete it.
    Posted (edited) · Improve the interface of the Support Blocker
    I would suggest not manipulating the support blockers in Layer View. Layer View shows the sliced result, after a lot of calculation. That's why it takes a long time to update after changing the support blockers.
    In the normal "Solid view", you can see the areas that will get supports added in red. Click those red areas if you don't want those areas supported. Then switch to "Layer view" to check if everything got sliced ok. That's the intended use of Support blockers.
    Update: a tip on Layer View: set the Color Scheme to "Line Type". That makes it much clearer what is support and what is not.
    Edited by ahoeben
    I was reviewing your suggestion and got to the conclusion that it will not work, because there is no precision in the areas painted red. Check this example that I am currently working on.You can see clearly that the red painted area do not correspond exactly to where each of the supports go. I even think that we should be able to remove parts of a given support.
