You did not model it with inverted faces, but probably with too many walls. This happens when boolean operations go wrong, or there was no boolean. I don't know enough about your specific model or inventor to be sure.
1
ahoeben 1,968
Yes, probably. Can you check the model in X-Ray view? If there are red areas in X-Ray view, your model has "internal geometry", and Cura looses count what is inside and what is outside.
Care to share the STL file?
Note that STL files do not contain units, so Cura can only make an assumption to the unit that was used while modeling. Since Cura can't read your mind, it always assumes the unit is MM (and you probably modeled in CM if you have to scale the model up to 1000%).
bizilux 0
sharing STL file is not a problem, im releasing it on thingiverse when its done anyways...
and yes its all red, so i modeleded something wrong, did i model it with inverted faces? im trying to find out how to invert faces in inventor but its unnecessarily complicated
Part3.stl
