It does also happen saving to the main SSD on my machine.
However I have fixed the problem without knowing exactly what caused it. I uninstalled both 3.4.1 and 3.5 again and then hunted around the disc for anything still remaining. There were 'cura' folders under my AppData/Local and AppData/Roaming folders. I deleted both of these and then reinstalled 3.5. Now the save is instantaneous.
I am trying to think what parameters I might have been adjusting at the time and I have an inkling it might have been the experimental Enable Bridge Settings parameters.
Hope this helps someone anyway!
Simon
ahoeben 1,852
Do you perhaps have (m)any postprocessing scripts active?
Does this also happen if you save the gcode to another drive (eg to your desktop)?
