hi I guess I have a similar issue
should the above fix will do it?
if not can you suggest what will be the solution for it?
tnx
Cura.exe |
0.0.0.0 |
5bd2dc78 |
atio6axx.dll |
6.14.10.11411 |
4f150261 |
c0000005 |
0000000000814857 |
11f0 |
01d49c1bb0242660 |
C:\Program Files\Ultimaker Cura 3.6\Cura.exe |
C:\Windows\system32\atio6axx.dll |
f6f730ba-080e-11e9-9743-00a0c6000000 |
nallath 1,104
Seems to be an issue with your drivers. Are you on the latest version?
mhutchinson 0
To be more specific, it appears to be your Graphics driver. Looks like you have an ATI video card or chipset. You will need to make sure that you have the latest drivers installed. If this still fails, then you will likely need to do the following:
ATI has historically had driver issues with abandoned files and registry settings making apps fail. I've used this in the past with fairly good results. It is NOT guaranteed to solve your problem though.
