Thanks. This message says nothing about “per model” though; it tells you that there are errors in some setting values. These settings may be “hidden” in your sidebar, but that does not mean they don’t have an (illegal) value. Use the search in the sidebar to look for the setting, and make their values legal (eg prime tower location has yo be inside the buildplate, whether a prime tower is printed or not)
In the little box underneath the model on the build plate it says "unable to slice due to some per-model settings". I can see if I set these things in my profile but it does say per-model in the error message.
Ok, so here is what I did. I had to un-hide the gradual infill steps height box in my profile by putting a value in the gradual infill steps box. Then I entered a value in the infill steps height box of 1. After that, I set the gradual infill steps back to zero, which hid the box for gradual infill step height but retained the value in the profile. Now that there is a 1 in there, regardless of the status of the infill steps, I no longer get the "per-model settings" error. And it makes no further mention of prime tower position either.
-Brian
Glad to see you got it working, and sorry for not reading the message box; there's a very similar message that does not mention the per-model settings, and I assumed that you got that one.
ahoeben 1,850
Could you add a screenshot of the message? Slicing should not require per model settings, and I can't think of anywhere in the code where such a message is created.
