Thanks for response, It is definitely 1.75 in machine settings - I had thought that at first as well, the first time I created the printer it was 2.85 and I changed it to 1.75. When I reopen the settings it says 1.75 as well. I tried restarting after setting it as well, I also verified after the restart that the setting stayed at 1.75.
I did not verify the filament settings on the right though, I think from memory filament diameter is also set there for the material choice - I will double check when I get home.
ahoeben 1,652
Can you check the material diameter in Machine Settings? I think it might be set to 2.85
