Ok, that sounds logical ?
Which logs do you need?
Thanks
Crash while saving/exporting ANY file
- 1 month later...
Same here on a Chuwi Lapbook Air with same CPU/GPU as in initial post.
Crash on every save operation.
Works well on 10yo ASUS Laptop with Core2Duo T9900 and Geforce 9650GT
Also curious: Celeron N3450 and Core2Duo T9900 shall have comparable performance, slicing same model takes 10s on T9900 but 5 Minutes on N3450.
Tried 3 different graphic driver revisions for N3450 with same result
Ugh, logs don't show anything. Could you try disabling "send slice data" in the preferences? On some machines the SSL certifications cause crashes.
1
4 hours ago, nallath said:Ugh, logs don't show anything. Could you try disabling "send slice data" in the preferences? On some machines the SSL certifications cause crashes.
success!
i disabled send print information and now it works.
thank you for your help
Worked for me as well!
Slicing seems to speed up also.
Thanks for advice
nallath 1,067
As is tradition; Without logs there is nothing we can do to help you.
