Update your graphic drivers.
- 1
have same problem and all graphix drivers are updated
Ended up fixing mine by uninstalling nvidia completely and installing once again, installing the latest drivers as well.
Excellent Brink, that made me go check that out.....in a roundabout way it led me to that my java was too old....long story short after updating java everything is working.....
Interestingly, after a few days of perfect software use. My problem has returned! Going to have to mess around with the drivers some more by the looks of it. Very odd ?
got the exact same problem today....worked perfect till today
Quick update: No fix for it so far, but I've pretty much learnt to deal with it, thankfully all the print settings load fine besides profile selecting, so no need for constant restarts
Brink 1
Hi all.
Quick update, I just installed Cura 15.04.3 which came with the Ender 3, which seems to be working fine. Although as far as I've read this is older software and I can see some limitations in setup/profiles for printing.
I reinstalled again using, removing the appdata cura folder which seems to have resolved the issue I was having with the crashes. I can now install any cura version (back to 3.2) and it works. What I am left with is software that has menus that load for about 7 'hovers'. By hover i mean I can see the menu drop down items. After this it goes blank and almost all options disappear across the software.
cura.zip
Edited by BrinkAdded Cura Logs
