1 hour ago, smartavionics said:Hello @jiberan, the problem is that it is doing a relatively long travel move without retraction immediately before the outer wall is started. There are two settings in the travel category that can help you here. You can either enable Retract Before Outer Wall or you can set Max Comb Distance With No Retract to a value such as 10 which will make all combed travel moves longer than 10mm use retraction. Hope this helps.
Combing mode have no effect. Combing mode: Off - the exactly same like before.
Combing mode: Not in Skin + Retract Before Outer Wall - (on pictures down) gaps at the beginning little shorter, but still missing material at the beginning outer wall. I think in this case not help this setting, but only the shortest travel distance.
burtoogle 510
