tinkergnome 927
no way... because.. it depends... ? (mainly on the firmware that you want to use with your mod...)
In case of Marlin firmware one can remove the feeder motor, fans and heaters - basically everything but the temperature sensor.
If all heaters are disconnected one can even safely replace the temperature sensor with an adequate resistor.
And if one is willing to modify the firmware the only limit are the mechanical properties of the device.
