First off, kill off the pythonw process like gr5 suggested. Then, goto the cura installation folder, there should be an output.txt, I'm very interrested in the contents of that file.
(Cura developer here btw)
OK, I have done as you said and I found an exception trace in the output file. It is repeated several times, but it's always the same one. There it goes:
Traceback (most recent call last):
File "C:\Program Files (x86)\Cura_13.06.4\python\lib\site-packages\wx-2.8-msw-unicode\wx\_core.py", line 14660, in <lambda>
lambda event: event.callable(*event.args, **event.kw) )
File "Cura\gui\splashScreen.py", line 16, in DoCallback
self.callback()
File "Cura\gui\app.py", line 41, in afterSplashCallback
from Cura.gui import mainWindow
File "Cura\gui\mainWindow.py", line 16, in <module>
from Cura.gui import sceneView
File "Cura\gui\sceneView.py", line 19, in <module>
from Cura.util import meshLoader
File "Cura\util\meshLoader.py", line 6, in <module>
from Cura.util.meshLoaders import dae
File "Cura\util\meshLoaders\dae.py", line 4, in <module>
from xml.parsers.expat import ParserCreate
File "C:\Python27\Lib\xml\parsers\expat.py", line 4, in <module>
from pyexpat import *
ImportError: DLL load failed: No se encontró el proceso especificado.
So, somehow the pyexpat module is missing. I tried to install it via easy_install and pip and it didn't find anything for "pyexpat".
Thanks guys!
Hopefully Daid knows what this is but... do you have 23 files in this folder?:
c:\python27\dlls\
If not then maybe reinstall cura? Or uninstall python27 and reinstall cura?
yep, 23 files in that folder exactly. I will wait for Daid's answer, in case he wants me to try something else. I think the most interesting part of this is to find out what went wrong during the installation process in order to fix it so it doesn't happen again.
Anyway, it could also be a one off situation, I'm a python developer myself, so my environment could be different to the usual user. But even then, it would be interesting to find the root cause of the problem.
Daid, I'm at your disposal to try whatever you think appropriate.
Cheers, and thank you for your help.
Odd, Cura comes packaged with a python install, and thus should not use files from C:\python27
You could try moving/uninstalling the python from C:/python27 or copy the Cura python from C:\Program Files (x86)\Cura_13.06.4\python\ to the C:\python27 location.
It is odd that this causes a conflict, I also have a python install and this does not cause issues. Could you try something for me? Do, "start"->"run"->"cmd" and there type "set", and post the result. It will be about 2 pages of data, and there might be something in there causing this issue. Once I know what it is I might be able to work around this in future versions.
There you go:
C:\Users\Pedro>set
ALLUSERSPROFILE=C:\ProgramData
APPDATA=C:\Users\Pedro\AppData\Roaming
asl.log=Destination=file
CLASSPATH=.;C:\Program Files (x86)\Java\jre7\lib\ext\QTJava.zip
CommonProgramFiles=C:\Program Files\Common Files
CommonProgramFiles(x86)=C:\Program Files (x86)\Common Files
CommonProgramW6432=C:\Program Files\Common Files
COMPUTERNAME=I7
ComSpec=C:\Windows\system32\cmd.exe
FP_NO_HOST_CHECK=NO
HOMEDRIVE=C:
HOMEPATH=\Users\Pedro
JAVA_HOME=C:\Program Files\Java\jdk1.7.0_21
LOCALAPPDATA=C:\Users\Pedro\AppData\Local
LOGONSERVER=\\I7
M2=C:\Program Files (x86)\Apache software foundation\apache-maven-3.0.4\bin
M2_HOME=C:\Program Files (x86)\Apache software foundation\apache-maven-3.0.4
NUMBER_OF_PROCESSORS=8
OS=Windows_NT
Path=C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files\TortoiseSVN\bin;C:\Pyth
on27;C:\Python27\Lib\site-packages\;C:\Python27\Scripts\;C:\Program Files\MATLAB\R2011a\runtime\win64;C:\Program Files\MATLAB\R2011a\bin;C:\Program Files (x86)\Google\google_appengine;C:\Program Files
(x86)\Apache software foundation\apache-maven-3.0.4\bin;C:\Program Files\TortoiseGit\bin;C:\Program Files (x86)\QuickTime\QTSystem\;C:\Program Files (x86)\Google\google_appengine\
PATHEXT=.COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH;.MSC
PROCESSOR_ARCHITECTURE=AMD64
PROCESSOR_IDENTIFIER=Intel64 Family 6 Model 26 Stepping 4, GenuineIntel
PROCESSOR_LEVEL=6
PROCESSOR_REVISION=1a04
ProgramData=C:\ProgramData
PROMPT=$P$G
PSModulePath=C:\Windows\system32\WindowsPowerShell\v1.0\Modules\
PUBLIC=C:\Users\Public
PythonPath=C:\Python27\Lib;C:\Python27\DLLs;C:\Python27\Lib\lib-tk
QTJAVA=C:\Program Files (x86)\Java\jre7\lib\ext\QTJava.zip
SESSIONNAME=Console
SystemDrive=C:
SystemRoot=C:\Windows
TEMP=C:\Users\Pedro\AppData\Local\Temp
TMP=C:\Users\Pedro\AppData\Local\Temp
USERDOMAIN=i7
USERNAME=Pedro
USERPROFILE=C:\Users\Pedro
VBOX_INSTALL_PATH=C:\Program Files\Oracle\VirtualBox\
windir=C:\Windows
XILINX_FOR_ALTIUM_OVERRIDE=
C:\Users\Pedro>
Thanks!
gr5 2,069
Strange. Well tech support would say "reboot your computer" so I guess you can try that. Before trying that I would go to task manager, "processes" tab and halt anything called "steamEngine" (unlikely to be running) or pythonw. If it does the same thing again, I think there is a log file somewhere. Look in the installation folder and subfolders for a log file dated newer than all the other files in there (dated when you launched cura).
Non english ascii characters have caused lots of problems in Cura so make sure the folder that Cura installed in has normal ascii characters.
