Posted · MatterHackers - NylonG
MatterHackers makes NylonG available to Ultimaker users via our material alliance in Cura.
You can access all available materials via Cura > Marketplace > Materials.
Are you curious about others experiences using NylonG or do you have any other questions regarding this filament? Feel free to post them below.
Some links you might find useful:
Technical Data Sheet NylonG.pdf
Safety Data Sheet NylonG.pdf
Printing Guidelines
    • 2 months later...
    It looks like the profile was indeed removed due to a technical error. We've reached out to them and they were going through the process on getting it back online again. Our apologies for the inconvenience.
    • Thanks 1
    • 4 weeks later...
    • 4 weeks later...
    I recently added the Matterhackers Nylon G profile to my printer from the marketplace. I have the S5 Pro bundle with material station, I can load the filament and select the type, but when I go to start a print it says that the material is not loaded into the machine. Also when I look at the machine in Cura it shows extruder #1 as empty - even though that is the one that I loaded the material to.
    I ultimately had to delete the marketplace profile from my machine and create a profile from the generic GFF Nylon, then it printed without any issues.
