how did you sign in so you can restore your profiles? im using the same version of cura i was before so it should be extremely easy but somehow i cannot for the life of me figure out how to find out where i can restore my backups
In older versions of Cura, you needed to download the backup plugin from the marketplace.
Also; The restoring backups from older versions has been fixed. From 4.1 onward you should be able to restore backups from previous versions.
nallath 1,125
I just looked at the code and it was explicitly set to behave this way. Why this was done, I don't know, as Cura should be perfectly able to restore older data, since it has upgrade scripts.
I will investigate a bit more to figure out why it's configured this way (and if there is no reason for it, change it)
