Well @zungara, that was exactly it. Problem solved. No idea, though, why the material made a difference on extruder 1.
Thanks and Happy Holidays!
1
Hopefully you have happy Holidays. In Germany there are right now no holidays like you have in USA. 🙂
Good to hear you are able to solve you problem.
zungara 9
I had got the same error that a small object extend the build volume. I used both print cores and i had moved the prime tower a print before. After correcting the position of the prime tower every thing works. It was a little bit funny, because you can't see the prime tower at this point of placing the object. You have to remember what you have done the print before.
