how to save configuration option menù.
nasosan
Posted · how to save configuration option menù.
If you 'Save' a project to .3MF (as opposed to 'Export'), the print-settings used should be saved to that project file. So if you open that model again, the settings used when the save was made will be reloaded.
Unless you choose otherwise in the menu that should pop-up; to load the settings, choose 'Open as Project' when asked, 'Import Models' will of course load the model only. After that you may need to choose 'Update existing' in the next menu, depending on if the printer used in that file was already in your list.
        • 1 reply
