Cura 3D ignoring every printing speed setting!
pivor
Posted · Cura 3D ignoring every printing speed setting!
Please help cause im running out of options :(.
Since few weeks, no matter what kind of printing speed settings i set in cura 3D, it always prints with same speed (1st layer, walls, supports, etc.) even if i set 10mm/sec it still goes around 60mm/sec.
I tried reinstalling Cura 3D and deleting my presets and used stock ones and other computer.
Everything works fine with other slicers tho.
Please help, thank you in advance.
    Maybe the wrong gcode flavor for your printer?
    I can only be something that the gcodes generated by Cura are not compatible with your printer.
    • 5 months later...
    3 hours ago, Raziorx said:
    I got exactly the same issue... I'm stuck 😕
    If this helps, not bes lt solution but i managed to fix it by reinstalling Windows :s
    Oh my... 😂 Thanks for the tip !
    I tried setting separate speeds for my 2nd core yesterday (printing text using a different color and smaller nozzle) and noticed it didn't seem to print slower for that material at all.  I set it to 15mm/ps for all line types and it screamed through that part of the print just as fast as the other material, which was set to 30mm/ps.  Using Cura 4.1 on an U3Ext with the latest firmware from a few days ago.
    Still get the issue here, i manage to print by putting "1 mm/s" in print speed... But it's definitely not the best... I don't get it 😕
