Disable Extruder 2 in Cura (via the menu) and you will see that you got all profiles back.
When there is an active/enabled extruder with 0.25 print core, then only the fine profile is shown, because the core isn't able to print other layer heights. And it doesn't matter is print core 2 is not used in your print, it is enough when it is enabled.
I tried it here with my Cura, as soon as I have selected a 0.25 print core in one extruder, I only see the Fine profile.
1
Thank you.
You are welcome Ghene 🙂
Is it working now for you?
- 1 month later...
On 11/27/2018 at 7:00 PM, Smithy said:You are welcome Ghene 🙂
Yes, ity is now.
That's fine!
And a happy new year 🙂
Smithy 1,146
I guess you have selected the AA 0.25 print core and therefore you see only the Fine profile. Check if you see more when selecting the AA 0.4 core.
Edited by SmithyLink to post
