6 minutes ago, ahoeben said:Perhaps you could explain what it is you have an issue with?
Your layer view is in "Compatibility mode". For the more advanced layer view, you need a GPU that supports OpenGL 4.1. If your GPU does not support this, it switches to this "Compatibility mode" which only requires OpenGL 2.
I am understand. My GPU is support OpenGL 3.2. Thank you for your explanation.
ahoeben 1,602
