Ok.
Install CURA fresh. Allow it to delete old profiles. I added ONLY a generic printer, set for 2 extruders. Use, verify functionality, quit CURA (done in the "before time"). Perhaps yours doesn't do this because you've installed an UM profile in your CURA? (I didn't test that)
To answer this post, I:
Load CURA 3.6.0
Right click, Disable second extruder
This notice, similar to but out of order from the lower notice shown in previous post appears.:
Not hard to reproduce on my end! No model, no nothing.
It seems to happen with Prime Tower enabled or disabled. The option always comes back on regardless of previous state when I enable the extruder.
nallath 1,125
I'm having some trouble reproducing this. If I disable an extruder, it never tries to change the prime_tower_enabled setting.
Could you share your exact reproduction steps?
