Trying to "present" print after finished, but Y = -10 so cannot move
Posted
· Trying to "present" print after finished, but Y = -10 so cannot move
First of all I would avoid the G91. You can reset the extruder to zero:
G92 E0
But I wouldn't reset any other axis. You can still use the G1 E-2
Now why are you moving the Y to position 220? That's all the way to the rear? Would it be better to move Z to 220?
I guess I need to see a photo of your particular printer. On the ultimaker printers, moving Z to 220 would make sense as that lowers the build plate down (the head doesn't move up and down on ultimaker printers).
wait - you must have a bed that moves in Y. Okay I like this - slide the print forward to the front of the printer. Just don't do this G91 at all as it is probably what is causing you the problems. G92 is much safer. G91 probably has bugs.
gr5 2,243
G92 E0
