Cura first gcode generated is retraction ?
creatron
Posted · Cura first gcode generated is retraction ?
My prints does not start immediately, due to the fact that it does not have filament, even if I print a huge skirt, and I mean huge. I then saw the very first gcode  generated by Cura is 5mm retraction
G92 E0.0                           ; reset extruder distance position
; end  startup code
G1 F2400 E-5
;LAYER_COUNT:51
;LAYER:0
M107
5mm retraction ? , I have a Crealiry CR10 4S, and a bowden need a lot of retraction, how can I switch this off, because this is the reason why the print does not start immediately. Currently I edit the file, but tends to forget and then the print is a flop.
Thanks
        • 1 reply
