Sure.. Please find the below attached for your ready reference.
Hi, which firmware are you running, and have you updated your firmware recently? If you can not connect online, you can also use USB to install it.
Regarding your prints; are your fans working? I doubt it based on that benchy print.
Re that other print, it looks like perhaps it is too hot, but perhaps you could also clean your threaded Z rod (and add the magna lube grease afterwards).
SandervG 1,518
Hi @vivek,
If you could add some photo's of what you're seeing that would be of great help 🙂
