Posted · tree support keeps getting hit
if i print a model with tree support enabled my Ender 3 keeps hitting the support if it goes from the model to the next layer. (detailed description at the end of this post)
i'm a forgetting a setting or is something else happening?
stats and settings:
running version 3.6.0 with no plugins.
i have "avoid printed parts when traveling" and "avoid support when traveling" enabled
and a "travel avoid distance" of 1.5 mm
combing mode = all (don't know if that matters)
if a is the outer wall of the support
b is the inner wall of the support
and M is the model
_a_b_M_
the layers start printing at a goes trough b stops at a.
goes from a around the supports to M.
prints M goes to a again but in a direct line (M to a shortest path) hitting the supports
        • 7 replies
