kmanstudios 1,120
I know that Blender can create a 'Surface of Revolution' (proper term) or 'revolve' in Maya and 'Lathe" In 3DS MAX. This would be the perfect object for such a function in any program.
I have seen too many people, no matter what software, try to do this with booleans or other destructive methods.
But, a lathe would be best.
Now, with THAT being said (to let you know a bit of modeling experience advice) I took a look at your file. Method of process is as follows:
- Looked at your 3MF file. Got the same results, but see no x-ray errors.
- Exported the file to an STL to run through 3DS MAX's 'STL Checker'. No errors in that file.
- Change the printer from yours (Prusa) to my native UM3E and it sliced ok
- Changing printers without relying on export and reload makes sure I am using your original file, only the printer definition changes
Slice in my native printer setup.
So, I would gather that something in the Prusa settings is not reading the file properly. I know nothing about the Prusa series so I am useless here, but hope that I have narrowed this down a bit for you to find a solution.
Smithy 1,145
Hi and welcome!
your STL file is probably not watertight, you can check it in Cura with the x-ray view and check if there are any red areas. (x-ray view is in the same menu as solid and layer view)
Blender is additionally not the best choice for such models, you will get better results with Tinkercad or Fusion 360 (both are free).
