Ah yes. One problem solved
Once again I have been proven wrong. The z hops are there, I thought I remember them being shown as vertical blue lines.
That would make it "0 things missing from Cura 3.6", which I know isn't true 😉
ahoeben 1,718
The layerview slider has two “nubs” that you can drag. If you drag the bottom one, lower layers become invisible. You can also drag the area between the two nubs.
