Cura (3.6.0) doesn't open 3mf file
mgibeault
Posted · Cura (3.6.0) doesn't open 3mf file
I saved my project that has several parts and several custom settings for the S5 into a .3mf file and now, if I try to open it, nothing shows. I tried both options presented to me, "open as project" or "import models" with the same result.
The file 186MB so there's something in there...
    Thanks for looking into this.
    I waited until the progress bar finished and disappeared. And just tried again and did not touch it for an hour with the same result.
    I tried with another, a little bit simpler, file and it opened fine in a few seconds.
    Would it be possible for you to share the file?
    No I can't, it's sensitive information (and it's 186MB)
    Just for people who encounters this problem, I don't know what was wrong... I did not see it again and was able to open a slightly different file of the same models. 😥
    Thanks for the update!
