Cura is currently not designed to handle the corner case single extrusion thin walls.
If you had posted this 12 hours ago I could look at it but I am away from home for 3 days so I can't open the STL. But I see the name mentions .5mm wall.
Just as a quick test, try setting your nozzle width to .2mm. See what happens in layer view in cura.
With a .4mm nozzle you can't print anything smaller than .8mm thick in X or Y.
Weird, I thought that smaller nozzles were able to print small perimeters. If my nozzle can realistically do .2mm, then for 5mm it would take roughly two perimeters. But since Daid said that it is not designed to do so now, I'll accept it.
I just wanted to print this single wall object to check the wall alignment and as a quick & dirty test for z-wobbling.
For now, I am using this object instead:
http://www.thingiverse.com/thing:17991
I recommend making a solid cube and set the top/bottom and infill to 0.
Thanks, I did it.
gr5 1,971
