I have attached the file and picture showing the bottom and the full part. The part looks great but the pic of the bottom shows what I am trying to fix. I would like the bottom of the part to be more solid.
For me, it looks like that the distance between bed and nozzle it to high and therefore the material will not be squished enough into the bed. Have you leveled your bed correctly?
What are your other settings? Line Width, Nozzle size, Layer Height, First layer Height? Would be much easier if you would post your Cura project here.
Do you see the problem already in the layer view in Cura?
I attached the file with the pics. Bed is level.
After looking, I would like the bottom and top layers to look like the walls. When it prints the perimeter the lines look good. When moves to the middle is when I get the spacing.
I figured out the issue in case anyone else has the same problem. Default settings have the top/bottom line width set to 0.4. Switching to 0.2 seems to produce a very nice surface finish.
burtoogle 508
How about posting some images and maybe even attaching the Cura project file so we can get an idea of what's happening?
