Grey areas
Humblebee
Posted (edited) · Grey areas
Hello,
I've got several models from the internet (STL file), and when I place it in Cura 3.6 it is okay. I have to scale them down or up to be in the right size. When I slice it and I look in layer view, then I see grey areas in the model. So this area's won't be printed. How can I correct this, or is there a setting I should look at?
kwingklein.stl
Edited by Humblebee
    These parts are too thin to print, for a circle, printed with a 0.4 nozzle, the diameter becomes 0.8. And they will not come out nice and strong if they would print this thin. Maybe add something solid to the model when printed, like a piece of filament, stick (wood, metal).
    Edited by peggyb
    • Thanks 1
