Is this an error?
moefinley
Posted · Is this an error?
The back of this model doesn't print well and while investigating I noticed this in Cura. This should be a consistently 2mm wide block (It's an extrusion in Fusion 360 with no taper). Why is Cura leaving this gap near the back? Thanks
