Posted · Python35.dll Missing
I've downloaded Cura, installed it, and ran it from the install screen. Worked fine. After exiting the program, I attempted to run it again. I get an error box that reads "The code execution cannot proceed because python35.dll was not found. Reinstalling the program may fix this problem." I uninstalled, then re-installed. Same problem. Any idea how to fix the problem? Don't really want to re-install the program every time I want to run it...
    • 1 year later...
    • 6 months later...
    I had the same problem. The first time you open the program it works, but when you try to open it by clicking on the icon, it doesn't work. The solution I found is the following: Instead of opening Cura via the icon on the desktop, you search for Cura in the Windows search thing that you open with the Windows-button. When you click here on the Cura icon it does work. You can also drag the icon from here to your desktop to create a new icon. This one now does work and you can delete the old icon from the desktop.
    • 1 year later...
    Good morning, I installed cura 5.0 on my pc but it doesn't open with two errors, one in the api and the other in the python DLL, I use windows 7 64bits, how can I solve this?
    [gr5 translated using google translate - only english in this part of the forum]
    Cura 5 absolutely will not work with windows 7.  Ever.  You can use Cura 4.10.  4.10 is the last version that supports windows 7.  Fortunately most older versions of Cura work very well and are loaded with hundreds of features.
