58 minutes ago, Smithy said:Is Fusion calling the batch or the exe file? Can you try if this makes any difference?
If I let fusion call the cura.exe file directly, I get a new cura instance for every make. If is use my batch file, with --single-instance, I get to reuse the running cura, but the build plate is cleared.
I think the mac I use in the office does do it the "right" way, like yours as well. This might be a windows only problem. (I have just updated the thread topic to indicate this)
Edited by mogul
Smithy 1,145
This is strange why it is not working for you out of the box. I am on a Mac but I do exactly what you did and have both parts on the plate without any switches.
I am not sure at the moment if there is an option in Cura preference which clears the plate and could cause this behavior but I assume no.
