I appreciate the feedback. I"m not really worried about changes in settings on general terms. When I slice something new and am happy with the prototype print I then save the Cura Project file which is inclusive of the model, settings and placement.
Also... Each instance is a different machine. So I don't have a concern for 3 instance of the same machine, with only one saving.
Which is why I often have instances open.
Slice object 1 on printer 1 - print it
Slice object 2 for printer 2 - print it
When #1 is done, make adjustments, print it
{repeat until happy}
Save the Cura project file for future use.
ahoeben 1,722
Note that running multiple instances of Cura simultaneously isn't really recommended. If you make changes to settings, only the changes of in the last Cura instance you close will be stored; the rest can be overwritten. It will work in some cases (eg if you really only use a single printer configuration in each instance), but generally it is not a great idea.
