Support structure offset
AndersK
Posted · Support structure offset
Can anyone point out which setting makes the support being built outside geometry when using PVA?
If I set extruder 2 to PLA it looks like second pic.
First pic is PLA + PVA (purple)
Second is PLA both (Brim is PVA):
    I guess it is to prevent creating lots of small "islands" of support on some prints. Since PVA does not stick very well to PLA, these would have a larger chance of tipping over. And it should not do much harm because it will dissolve anyway.
