Thanks for replying,
I'm sorry, I should have given more information though I didn't think of it at the time.
It may be hard to tell in the pictures but the boxes are 32mm x 42mm, 12mm tall. Walls are 2mm in CAD but actually 2.2mm.
Yes I'm using PLA.
The piece that is breaking off sits on top of the round studs by the rectangle holes. There 2.5mm in diameter and 3mm tall. At 20% infill they broke off the first couple I made.
My biggest problem is a lot of stringing on the studs at 100% infill. That is mostly what I'm trying to solve but It may be better after thinking about it to use screws but I'm trying to conserve on weight because it is going on a quad-copter. Oh and the supports being to thick to pop out easily. When I did 100% the infill change to lines.
The lid that I haven't made yet was going to keep the circuit board held down.
Thanks,
Jeffery
gr5 2,224
Breaks off easily? That's not good. I'm guessing this is not PLA. I've never met someone with fingers strong enough that could break those support blocks off easily. It would take about 30 pounds (15 kg) of force. I mean if you had a screwdriver you could pry them off but not finger strength only.
I'm guessing these are printed in ABS and that you don't have good layer adhesion. The solution is to enclose your printer and get the air up to 35C and also to lower the fan speed to the lowest it will go to but still blow - about 50% rpm of normal. On an ultimaker 2 that would be 30% fan. On an S5 that would be 5% fan. Every printer is different.
