strange. I like Ian's explanation. But also check all the values in "file" "preferences". Particularly anything in mm.
Also it helps to run the "first run wizard" if you never did - you only have to answer the first question or two - telling it that you have an ultimaker. Or do you not have an ultimaker?
ian 32
mmmm do you have the mode file you tried to print ??
it could be.. sometimes if the model is not really clean, there can be some node points left over... a few meters away from the central 3d model object and then when cura tries to gcode it.. it of course tries its best to cater for all the 3d data.. including the extra spare nodes...
i just wonder is there some crazy 3d model trash hiding, that might have caused your printing problem....
Ian :-)
