Prints to thin
jefflundstrom
Posted · Prints to thin
Noob question here.  I just started using Cura with my New Matter ModT 3d Printer.  I used the profile I found on Thingiverse, but when I print the prints are about 1/2 the thickness (you can see through them) that printstudio creates.  The .stl file is exactly the same, the only difference is the slicer.  Can anyone tell me what setting I need to tweak to get my prints thicker?
Thanks in advance!
Jeff
