Check your pulleys if they are really tight enough, also the ones from the short belts. Additionally, check if there is some play on the axles when you try to push the axles fore- and backward. There are also good instructions on the UM website, how to check the play and how to solve that issue.
Â
Â
Â
Â
Â
Â
Reliable bed tilt compensation (no more thumbscrews) 2.4 and 5 GHz Wi-Fi A 1080p camera (mounted higher for a better view) Compatibility with 280+ Marketplace materials Compatibility with S5 project files (no reslicing needed) And a whole lot more Â
Â
We generated a special version of Cura 5.2 called 5.3.0 Alpha + Xmas. The only changes we introduced compared to UltiMaker Cura 5.2.1 are those which are needed for the new supports. So keep in mind, this is not a sneak peek for Cura 5.3 (there are some really cool new features coming up) but a spotlight release highlighting this new version of tree supports. Â
Smithy 1,135
