Cura Profile Location
bryansp_ms
  • 4 months later...
Posted · Cura Profile Location
On 7/7/2022 at 8:23 AM, ahoeben said:
This is untrue. The location that you mention/found is where default profiles are stored, not where user-created configuration data is stored. Cura cannot even write to the location you mention (unless you launch Cura with administrator privileges, which you should not do). The user-created configuration data is stored where it has been stored since Cura 2.5:
%APPDATA%\cura, in a folder with the name of the Cura version. So in most cases, for Cura 5.0, that would be C:\Users\[your username]\AppData\Roaming\cura\5.0
I cannot stress enough that it is inadvisable to change files in the Program Files\Ultimaker Cura 5.0\ folder.
It is true if you intend to edit boundaries that are restrictive after installing a different size bed, such as an Ender Extender. I have to edit it in the new program files location after every update to Cura. This Cura-Cure does the dirty work for all machine profiles that are relevantly inhibited by clip boundaries.
        • 26 replies
