Thanks for the reply gr5! I did as you suggested with no luck the layer view still only shows up in the lower left corner? I still think it has got to be a settings issue. Is anyone having success with a delta printer using Cura and this issue?
Thanks for the help!
Werner
gr5 1,968
Run the firstrun wizard (you don't need to connect to an UM). Answer just the first 2 pages and then when it wants to connect to your machine cancel out of the first run wizard. This will set up all the settings for you that are needed. The most important thing is to tell Cura that you have an Ultimaker. Then this should work fine.
