And most important with nylon, keep your spool dry! If you leave the spool outside of an airtight container for more than a few hours, the material absorbs too much moisture and you get serious extrusion problems.
So your spool is probably already wet - but you can dry it again in an oven for several hours. Check the forum for temperatures.
Smithy 1,132
Could be a clogged nozzle. Try to make some hot/cold pulls or if you want to do a quick check, use another AA print core.
