Teflon tube is sliding off from teflon insulator...
Posted
· Teflon tube is sliding off from teflon insulator...
"Bowden Popping"
You need to either: 1) print a thicker bowden-retaining clip and use it, or 2) re-tighten your hotend thumbscrews with more pre-loading compression on the bowden tube.
Should be an easy fix.
nick-foley 5
"Bowden Popping"
