Brains!
Axe
New to 3D printing, but not to modelling (experienced with Rhino, ZBrush, C4D, among others....).  This, however was a bit of a new experiment for me.  Printing my own brain from a 3D MRI dataset.  Always wanted my brain on my desk.....
This first one I sent to Shapeways to get printed through laser sintering.  Expensive, so I only got it printed 80% of actual size (and hollow).  Figured it would nice with lighting inside, and I couldn't resist putting the lightbulb over it - for when I want to signal I had a good idea!
I now have a Ultimaker S5, so I printed the second one full size out of Translucent Blue PET/G.  The most expensive part was filling the hollow structure with PVA.  Used half a spool for that!
Hope these animated GIFs attach properly - haven't posted before......
  • Like 4
I'l love to put the other GIFs here, but I keep getting error "-200" even though they are under the kb size limit.  Anyone know what that means?
    Posted (edited) · Brains!
    Ok, here's another try....  Had to upload them to my website then link them here.
    This is the first one showing how I made it into a lamp.
    3 different intensities depending on how "bright" my ideas are..........
    Edited by Axe
    added info
    And on its stand (stand printed in Ultimaker Pearl White PLA).  The stand has a compartment for the battery pack/controller for the LED lights with a sliding cover.
    I think my wife might get tired of my brains spread around the house......
    I loaded the DICOM file onto a proprietary workstation and used the MRI vendor's software to export an STL file.  I needed to do quite a bit of editing/segmenting to remove the skull, vessels and other soft tissue before generating the model.  I may try using "Slicer" next time as I understand it has pretty decent segmenting tools and is free (so I can do it at home instead of at the MRI site).
    After export I loaded the model into ZBrush to do some further clean up before re-exporting from ZBrush as another STL.  Fairly labour-intensive.
    Also used ZBrush to hollow out the model, leaving the walls just under 2mm thick.
    Edited by Axe
    added info
