ITX Case
jeracom
Posted (edited) · ITX Case
ITX case for 6,7 ร— 6,7 Zoll boards (Case 19cm x 19cm x 7,7cm LBH). Print in PETG, of course you can also take something else ๐Ÿ™‚ . It took me a moment to get everything right. The rear panel also fits now.
The kit consists of housing, the housing cover.(in DIFFERENT VERSIONS) The front panel, made of two parts, and the associated buttons with the back brackets for the PC switches.
Front panel, two versions with magnet or with metal pin. Front On Off, open, closed LED cover.
Front panel, buttons, magnets I glued with 2K glue.
Below the board is a HDD-bag that can hold two 2.5 Zoll disks. Under the board is also an M2 slot.
In addition two fan grille, which I covered with insect screen. There is nothing screwed except the motherboard. The rest is fixed with Neodym magnets. Also easy to open.
I take a 35 watt CPU
Since I work with electricity, I take no warranty
Sata cables etc ...
I have used the following parts:
Ich habe folgend Teile benutzt:
PC Reset Schalter Kable ATX Power-Reset HDD https://www.amazon.de/gp/product/B07BT3ZZ8X/ref=ppx_yo_dt_b_asin_title_o05__o00_s01?ie=UTF8&psc=1
Thermaltake Engine 27 https://www.amazon.de/gp/product/B01M4J64GU/ref=ppx_yo_dt_b_asin_title_o06__o00_s01?ie=UTF8&psc=1
LEICKE Netzteil 120 Watt 12V https://www.amazon.de/gp/product/B006Z9TQE6/ref=ppx_yo_dt_b_asin_title_o05__o00_s00?ie=UTF8&psc=1
PicoPSU-150-XT 150W 12V DC-DC ATX Netzteil https://www.amazon.de/gp/product/B0045IXKTQ/ref=ppx_yo_dt_b_asin_title_o06__o00_s02?ie=UTF8&psc=1
Neodym Magnete 10x2 mm https://www.amazon.de/gp/product/B06X977K8L/ref=ppx_yo_dt_b_asin_title_o07__o00_s00?ie=UTF8&psc=1
ย
Find on Thingiverse
https://www.thingiverse.com/thing:3409531
Ultimaker 2+
Resolution 0,2
Infill: 35%
Print in PETG
ย
Edited by jeracom
    • UltiMaker Cura 5.8 Stable released ๐ŸŽ‰
