I would turn off retract before outer wall. It probably oozed a bit during travel moves and then underextruded on the pillars.
For something like this, you are a lot better off not printing it as one piece. Not only would you have a heap of print time and PVA but you could get a lot better quality pillars. If you designed this yourself then you can make the pillars slot into place and add a dab of glue.
S-Line Firmware 8.3.0 was released Nov. 20th on the "Latest" firmware branch.
This update is for...
All UltiMaker S series
New features
Temperature status. During print preparation, the temperatures of the print cores and build plate will be shown on the display. This gives a better indication of the progress and remaining wait time. Save log files in paused state. It is now possible to save the printer's log files to USB if the currently active print job is paused. Previously, the Dump logs to USB option was only enabled if the printer was in idle state. Confirm print removal via Digital Factory. If the printer is connected to the Digital Factory, it is now possible to confirm the removal of a previous print job via the Digital Factory interface. This is useful in situations where the build plate is clear, but the operator forgot to select Confirm removal on the printer’s display. Visit this page for more information about this feature.
Labern 774
APuser 0
Thank you, pretty sure this was a temperature issue, and appreciate advice on recommended profile settings.
