Do these areas need support?
Dan_Noviun
Posted · Do these areas need support?
We're preparing a print and in Cura these windows (and other similar windows around the model) require support material? Is this normal? I know there is essentially an overhang on the lintels but I'm just not sure it needs it?
Any suggestions welcome!
    Posted (edited) · Do these areas need support?
    Typically bridges (aka horizontal overhangs between two edges) up to a length of about 7-8mm are fine without support on an Ultimaker printer. If they are longer, special bridging settings could be applied or you (more easily) print it with support.
    Edited by Dim3nsioneer
    When you say 'bridging' supports, what do you mean by that and where can I find a setting for it?
    Without support they will tend to sag a bit for the first couple of layers but it will not adversely affect the model over the top. You could mitigate for this by adding a window and frame within the openings perhaps. or consider printing these facades flat and glueing together afterwards if you cannot use support materials
