That's right.
- 1
That's right.
I have some questions about Combing. Rather than start a new thread I thought I'd piggy-back on this one. For reference, I'm using smartavionics fork of Cura.master; there's some very cool stuff going on in there. I really like the Small Perimeters setting and this should definitely be merged into the main branch.
I noticed that the Max Combing Distace default is now 30mm. I recall it being much lower than that in previous versions (but I could be wrong about that). Is 10-20mm still recommended? What factors go into choosing that distance?
Does Cura compensate for the extrudite lost during the unretracted travel move?
Edited by Reywas
burtoogle 516
Hello @MakMakMo, set the max comb distance without retract to something like 10 or 20.
MakMakMo 0
So if I am understanding this correctly, this will comb and also retract before longer travel moves over the set distance. So the comb+retraction will not enable oozing filament to be lost gliding over the print?
